Creating DAQmx 8.6 installer
Hi.
I use the NI 6221 device, 1 AO and 5 AI. I created the VI, made the exe. When the installer was making, there was a message "...insert the NI DAQmx 8.6 disc 1...". I inserted the disc, pressed the button OK, but the message remained. I did this action several times, but nothing changed.
What have I to do?
Thank You.
Dmitry.
(2,786 Views)
I have solved this problem, but there is another one. I created installer, the weight 700 Mb. I Installed it on the other computer, then ran the application and there was message " ..  can't find the front panel, Daqmx Stop Read, Start Read,...". What does it mean?
Thank You.
Dmitry.
(2,772 Views)
Hi Dmitry,
your installer takes 700 MB?? The message mean that these vi´s have no front panel, maybe the application builder removed them. Can you explain what you try to do?
Mike
(2,770 Views)
1. Open VI
2. Took Project, New Project.
3. Add VI to the project
4. Took Build Specifications, Application
5. Saved the project
6. Took Source File
7. Pressed Build, Done
8. Took Build Specif, Installer, Sorce File
9. Took Addition Installers, NI-DAQmx 8.6
10. Pressed Build, Done.
The weight of the My Installer is 716 Mb
(2,764 Views)
