Create .wav sound file
Hi all,
I'm trying to load two channels .wav file and split it into two different files where each file is one of the channels.
When I trying to run the program I get an error says that there is no file at the path I choose to save the new files but there shouldn't be files in those paths because I want to create them for the two new .wav files.
I attach images of the program and the error.
I'll be glad if you can help me understand why I get this error and how can I fix it.
Noy.
(3,131 Views)
Which of the File Open functions is throwing the error?
What is the value in the file path wire coming out of the Express VI?
Is it a folder?  If so, you'll get an error because you didn't pick a specific file you wanted to open.
If it is a file, then you'll get errors because you are appending a file name to then end of a file path that already includes a file name.  LabVIEW will then think that the original filename is a folder, which of course doesn't exist.
Make sure you have 3 accurate files names in all the file paths going to the 3 opens.
You may need to do a Strip Path on the original filename then do your Build Path with a new file name for the 2 new files.
(3,121 Views)
Thank you very much for your answer!
The problem was, as you said,  the path I connect to the new files.
I changed the path to the folder of the file I read and the problem solved.
Tnx!
Noy.
(3,113 Views)
