Create via ActiveX Labview a XY Scatter plot graph on an excel sheet
I am trying to plot an XY Scatter graph on an Excel sheet using LabView ActiveX function.
How do you pass the data (2 different columns)to the Graph wizard?
Thanks for any help.
(5,889 Views)
Satt,
here is a version of the VI which should work.
-Norbert B.
NI Germany
Norbert
Expert: Geometry
(5,889 Views)
Thanks Norbert but could you please convert the VI to Labview Version 7.0 so that I could open it.
(5,889 Views)
Satt,
Sure, here we go 🙂
Norbert
Expert: Geometry
(5,889 Views)
Sir my values are loaded in Excel sheet. I want to retrive it and again store it in excel with XY graph.. i'm leaner so i struct hard so please help me with a VI.
It always shows an error.
Error -2147352571 occurred at Type mismatch.
 in XY Scatter excel plot_end.VI
(4,676 Views)
It seems the SetSourceData Method is actually expecting the value instead of the name. By choosing to input value 2,
the VI plots the data as intended. See this VBA reference page from MS.
-Baalshillem
(3,814 Views)
