Create uninstaller exe with application builder
Hi!
Im using LabVIEW 8.5. I have created an application with the app. builder, it works fine, also an installer.
But I need an UNINSTALLER, like Uninstall.exe to be created also.
I have found a NI doc, which says:
"The Create Uninstaller option was removed from the
Advanced Installer Settings dialog box because the Application
Builder always creates an uninstaller"
But where can I find it?
im able to uninstall my app, using the Windows add/remove softwares option, but i need an exe.
Can you help me?
Waszil
(3,683 Views)
Since the installer is based on Microsoft technology and the Microsoft standard is to only have the Add/Remove option, you cannot create an uninstall.exe with LabVIEW. I'm not even sure why would would need to if everything works with Add/Remove Programs and that is what everyone is used to now. In any case, there are probably some commercial installer packages available that still support the old technology.
(3,666 Views)
Yes, it works that way, anyway, I like when a program has the uninstall option in its Start Menu group. Well, if it not possible, then all right.
Thanks anyway.
(3,629 Views)
