Create timeout in sub vi
I am using the Database connectivity tool box to communicate with a database on the local network. Unfortunately, the CommandTimeout parameter is not supported by my client, and I need to kill a query which is too long and holds the rest of the process. Has anyone encountered this issue?
Basically, I would like to encapsulate my query block into something that stops the query and replace missing values by NaN if it exceeds a certain time.
It sounds simple but I haven't found any way of doing this so maybe it's not!
Thanks in advance!
(1,435 Views)
I dont know if its the best way (probably not), but you could run a SubVI (with your query) asyncronously and wait for the value(you could set a default value and wait for a change) if nothing happens and the "time has elapsed" then set NaN and continue your processes.
My Channel: https://www.youtube.com/@LV_Lab
(1,362 Views)
