Create new Actor generates Error
I'll warn you, I'm a total newb to the Actor Framework.
Here's my situation:
http://i.imgur.com/LwzaGMX.png
I know I'm using some experimental stuff here, but I have a co worker who I beleive has successfully managed to implement new actors this way.  I just did a search for an updated version of the AF msg maker but I didn't find one with a google search. I'm also not sure of the risk if multiple developers attempt to contribute libraries (resources) made by different versions if I switch from what I currently have (which matches my coworkers versions).
Can anyone shine some light on this?
(2,697 Views)
The first thing I would suggest would be to use Source Code Control to make sure you can manage the various versions of your code.
Software Configuration Management in LabVIEW:
https://www.ni.com/en/support/documentation/supplemental/06/software-configuration-management-and-la...
(2,635 Views)
