Create multiple Files in a common Folder
Hello LabView enthusiasts,
I use multiple sensors to measure the pressure in a room. I have a task to store the measured data in a csv- file. The storage of the data and its timestamp is possible by my written program. However, I don't want to enter the file path every time I open my program (because the task is extended by 30 additional sensors and this would be quite time-consuming). For this reason I considered to create a File in a folder when starting the program, in order to save time and make the programm more efficient.
Is it possible to generate several different files with different data in a common folder?
Unfortunately I did not find a successful solution. Does anyone have an idea or a starting point how to solve this problem?
In the apendix the vi and one image of the programm with multiple sensors.
Thanks for any help!
Cheers
Jason
(4,097 Views)
Hi Jason,
just as I wrote a minute ago here
(4,057 Views)
Personally, I like to put Date/Time stamps in my data file names.  So I can use Format Into String and Build Path functions to create the file path that I need.
(4,033 Views)
That is usually a good idea.  And doing it in YY-MM-DD_HH:MM:SS format and the alphabetical sorting of the filenames will also coincide with chronological ordering.
(4,003 Views)
Hey Gerd,
unfortunetaly I have Labview 2013 which doesn t support the "Create File with Incrementing Suffix" Vi. Can I program it by myself or is it even possible??
Cheers
Jason
(3,926 Views)
Hi Jason,
Yes, you can program it for yourself!
Spoiler
ListFolders to get the current list of files, find the latest file, create a new filename based on your rules, create a new file…
(3,919 Views)
Just to close this loop...
I actually tend to use YYYY-MM-DD HH-MM-SS format.  Y2k (and Y3k) compliant!  It also makes it very obvious what is the year.  And, yes, the sorting is a bonus.  Here is a somewhat typical way I will create a log/report file path.
(3,903 Views)
