12-06-2007 07:18 AM
12-07-2007 01:43 PM
Hey Megahall,
Thank you for National Instruments. I have been trying to locate some documentation that may help you out, but so far I have turned up nothing. I do have a couple of questions for you.
1) Is there any reason you have chosen to build a lsb file, and use the CIN node in LabVIEW? It may be easier to create a dll, and use the Call Library Function node.
2) What version of Microsoft Visual Studio are you using?
3) I want to clarify that you are using "Microsoft Visual C++ 5.0 Express." I have not been able to locate much information at all on this version of MVC++.
I look forward to hearing back from you.
Kevin H
