Create installer with source files
Hello
I have a word search game and i have a dictionary and  the VI create one file with "last scores". I want to creat installer which indclude this files when im setup in another computer without labview.
Thank you!
(4,254 Views)
Accepted by topic author Blen86
First of all, you need to be using a project.  The project should include any source files and any other files you will want to include in your installer.
Then you create a build specification for an executable.  Once that is built, make a build spec for the installer.  The installer should include any NI compenents you may need to run your program (like the Run-Time Engine).  You can also specify where files will be installed..
(4,248 Views)
I created the projet, and now how can i add my txt and etc... to project? Basicly i only see the VI.
(4,239 Views)
You could just drag the file from Windows Explorer into the project.  Or Right-click on the My Computer and choose Add File.  You can add any type of file to the project.
(4,234 Views)
Thank you, i think this will be complicated. Realy thank you for fast reply
(4,221 Views)
