Create folder in LV 7.1
Is it possible to create a folder in LV 7.1 For date saving?
"Thanks with regards "
by
..........Gireesh..........
(2,984 Views)
Yes. Have you looked at the File I/O>Advanced palette?
(2,980 Views)
No ! ! ?
by
(2,971 Views)
@gireesh wrote:
No ! ! ?
Then why don't you try doing so.
(2,965 Views)
Hi friend I need to know how to create the folder in LABVEW 7.1 programatically then as well as i need to open an test file with in that folder itseif.
Srinivasan.P
(2,866 Views)
As noted, have you looked in the File I/O palette? The function you want is there. have you looked at the LabVIEW Help?
again, look at the File I/O palette. The functions you want are there.
To learn more about LabVIEW it is recommended that you go through the introduction material, tutorial(s), and other material in the NI Developer Zone's Learning Center which provides links to other materials and other tutorials. You can also take the online courses for free.
(2,850 Views)
