Create an XY oscilloscope
 Use two signals coming from the myDAQ (1000 samples, 500 Hz)
Use a multiplication factor (Knob) for each channel, using a ring control: 2, 1, 0.5, 0.1 V/div
Use a variable shift for each channel (Knob)
Use a zero signal with a toggle switch for each channel
Make the scales (X and Y) fixed (-10 to 10)
How to do this?
With kind regards Dirk Floren
(3,081 Views)
Hi Dirk,
is this some kind of homework? Your "description" sounds like…
How to do this?
Just follow the hints given in the questions!
- Use DAQmx to read samples as requested
- create a ring control, use the result to multiply your data with
- add a "shift" (aka offset) to your data
- build a zeroing part using a toggle switch
- set the properties of your XY graph
Where exactly do you have problems with?
Did you take the free online beginner courses offered by NI?
(Keep in mind: we don't provide homework for free!)
(3,072 Views)
