Create a not User Event
Hi ,
I would like to create an event generated by a not user event,
here is my example but it it doesn't work, it doesn't show the message "value changed"
Help
Simone
ps: I do not want to use "signaling" method
Message 1 of 21
(4,343 Views)
Well, an indicator can only generate an event through value(signal), else you'll have to use user event. So you're out of luck trying to dodge both. 🙂
However user event are quite easy to use, look at attached file.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 21
(4,333 Views)
Value change applies to controls, not indicators.
What are you actually trying to do? Maybe someone can suggest an option for you.
Lynn
Message 3 of 21
(4,327 Views)
Lynn
The property works on indicators as well. 🙂
/Y
Qestit Systems
Message 4 of 21
(4,320 Views)
Yamaeda,
Do you mean the Value (Signaling) property or the Value Changed event? I agree that Value (Signaling) works on indicators. I cannot get a Value Chaged event work on an indicator.
Lynn
Message 5 of 21
(4,312 Views)
I wanted to take only the events that have changed in daqmx
Message 6 of 21
(4,305 Views)
The attached file is what i meant.
/Y
Qestit Systems
Message 7 of 21
(4,301 Views)
There should be a DaqMx event-example which should help you.
/Y
Qestit Systems
Message 8 of 21
(4,298 Views)
where is the example?
thanks
Message 9 of 21
(4,295 Views)
Since i dont have daqmx installed i dont have those specific examples, but Help->Find examples->hardware input/output if memory serves.
/Y
Qestit Systems
Message 10 of 21
(4,286 Views)
