Create a desktop PC utility USB drive
Hi, I am trying to createa bootable image for a target PC-104, using a USB dirve.
When I run NI-MAX and select TOOLS->RT Disk Utilities->Create Desktop PC Utility USB Drive, I can not select it, what is the problem
See the attach
(4,541 Views)
WSalas -
Have you verified if your computer meets the requirements to for your PC to work as a real time target
see this KB https://www.ni.com/en/support/documentation/supplemental/08/requirements-for-desktop-pcs-as-phar-lap...
Take a look at the document on Using Desktop PCs with LabVIEW RT for specifics on formatting, configuring, booting, and installing software on the target.
Best Regards
Bruno Noronha
Bruno Noronha
Certified LabVIEW Associate Developer
Using LabVIEW 8.6
(4,486 Views)
Just to make sure: do you have the LabVIEW Real-Time module installed on your development computer?
I have tried it at my own computer with and without the Real-Time module. Without the RT module the menu is grayed out, with the RT module themenu is available.
Peter S
(4,481 Views)
