Create a default path into Automation Refnum
I'm currently writing an app which should display a nice graph (chart) on
its front panel. I choose to use Mapinfo Active X.
To do this, I've placed an Automation Refnum on my front panel, and in the window
'select object form Type Library', I choose "Mapinfo.tlb" .
It works quite well, but :
When I re-open this Vi, I should re-setting the Automation refnum. I try to use Active X container, it doesn't work. Can I create a default path into the Automation Refnum or any other method which can solve this problem.
Thanks for your help.
(3,024 Views)
You shouldn't select the type lybrary, in automation refnum, when you want to select te type, available types appear if properly registered in your system, if not, you should register your tlb.
Hope this helps
(3,024 Views)
