Create a Folder in a FTP server
Hello, I need to create a New Folder on a FTP server but i don't know how to do.
I read about a MKD (make remote directory) command:
http://forums.ni.com/t5/LabVIEW/Create-a-folder-on-FTP-Server/td-p/1424906
but i didn't find it
(30,829 Views)
I could be very wrong about this (but I don't think so), but I suspect the hoops you need to jump through depend heavily on the FTP Server and what commands it accepts.  Then there's the issue of how you communicate with it ...
BS
(30,819 Views)
Sorry, I am able to comunicate with server (it is a FTP server created in Win7), i able to save a file in an existing folder but i don't know how to create a new folder...is there a command?
BS
(30,813 Views)
The command is MKDIR
Common FTP Commands
? to request help or information about the FTP commands
ascii to set the mode of file transfer to ASCII
(this is the default and transmits seven bits per character)
binary to set the mode of file transfer to binary
(the binary mode transmits all eight bits per byte and thus provides less chance of a transmission error and must be used to transmit files other than ASCII files)
bye to exit the FTP environment (same as quit)
cd to change directory on the remote machine
close to terminate a connection with another computer
  close brubeck closes the current FTP connection with brubeck,
  but still leaves you within the FTP environment.
delete to delete (remove) a file in the current remote directory (same as rm in UNIX)
get to copy one file from the remote machine to the local machine
  get ABC DEF copies file ABC in the current remote directory to (or on top of) a file named DEF in your current local directory.
  get ABC copies file ABC in the current remote directory to (or on top of) a file with the same name, ABC, in your current local directory.
help to request a list of all available FTP commands
lcd to change directory on your local machine (same as UNIX cd)
ls to list the names of the files in the current remote directory
mkdir to make a new directory within the current remote directory
mget to copy multiple files from the remote machine to the local machine;
  you are prompted for a y/n answer before transferring each file
  mget * copies all the files in the current remote directory to your current local directory, using the same filenames. Notice the use of the wild card character, *.
mput to copy multiple files from the local machine to the remote machine;
open to open a connection with another computer
  open brubeck opens a new FTP connection with brubeck;
  you must enter a username and password for a brubeck account
      (unless it is to be an anonymous connection).
put to copy one file from the local machine to the remote machine
pwd to find out the pathname of the current directory on the remote machine
quit to exit the FTP environment (same as bye)
rmdir to to remove (delete) a directory in the current remote directory
=== Engineer Ambiguously ===
(30,794 Views)
Sorry but i don't know how can I send this command with labview... is there a labview commandto send a ftp command?
(30,784 Views)
Ok I found ftp command.vi in ftp2.llb
Thanks|
(30,776 Views)
I would use the system exec.vi
(30,743 Views)
