Create Simulated myRio device
Dear All,
I would like to create Simulated myRIO device to use it to test my code while I don't have myRIO connected to the computer. I tried to use NI MAX explorer to create Simulated device as I do with normal DAQ cards. However, I can't find the myRIO available. Could you advice how can I test my code while I don't have myRIO connected.
Message 1 of 8
(9,002 Views)
Hi mawad,
you can do this in the LabVIEW project: just add a target to the project tree…
Message 2 of 8
(9,000 Views)
First you need to make LabVIEW project >>Then you can add device
may be you need driver for this
Please see this link
http://digital.ni.com/public.nsf/allkb/F466AD83D24F041D8625714900709583
Message 3 of 8
(8,995 Views)
Many thanks, GerdW. Is there any tutorial to show how to do it correctly?
Message 4 of 8
(8,994 Views)
Hi mawad,
just read the LabVIEW help on "projects"…
Right-click the top item of the project tree -> add target…
Message 5 of 8
(8,970 Views)
Many thanks, I tried the example on the link, but I get the following error when I run it "Failed to connect to the target"
Message 6 of 8
(8,969 Views)
Hi mawad,
how do you want to connect with a non-existing target?
Message 7 of 8
(8,962 Views)
There is no way to 'simulate' a myRIO target.
You can simulate FPGAs for most targets, but you can't simulate the RT part.
The best thing you can do is to run your code on Windows, accepting that anything that interfaces with the hardware will not work - you could always use a conditional disable diagram to run different code depending on the target (e.g. to simulate data coming from myRIO hardware instead of the actual data).
(blog)
Message 8 of 8
(8,957 Views)
