Create PXI Format Hard Drive Disk
 Can i use a "Create PXI Format Hard Drive Disk" created from LV 8.5.1 ver for formating the PXI RT controller which is having LV RT 7.1.
Regards
Aks
(Appreciate answers by giving KUDOS)
Hit the stars.............. sky is not the limit.
(3,590 Views)
I think you can, but you'll need LV (RT) 7.1 on the host PC to install LV RT 7.1 on the PXI controller using MAX after formatting it.
(Unless you have an image created by the RT replication toolkit, but then other problems might arise...)
Daniel
(3,588 Views)
