Create Database using LabVIEW
I need to create a database of list of 5-10 users containing the username, account number, mobile number, fingerprint. And verify whether the user is authorized or not based on the fingerprint.
How can I do this in LabVIEW or what steps should I follow to reach the output?
Suggestions Required!
(4,995 Views)
According to your specifications, there is no field that defines authorization. Is the mere presence in the database sufficient?
It would be a more interesting problem with millions of users, but with less than a dozen, "search array" on the array of fingerprints is probably all you need. How is the user database stored (array of clusters?).
(4,972 Views)
Dr.JDPowell has a fantastic SQLite package available on VIPM.  If you're looking for an easy-to-use and portable database, SQLite's the way to go.
You could also dump all of that data into a binary file, or a TDMS file.  I'm partial to binary files for overhead reasons, but if you're only ever going to have 5 users, it really doesn't matter.
(4,970 Views)
yes. Fingerprints & related info of user should be pre-stored.
And i'm using fingerprint sensor, using which i need to recognize whether the user's info is pre-stored or not.
just his/her info should be present in the database.
I have no idea where to start & how to create database!
Help needed!
(4,947 Views)
How is the fingerprint stored?
(4,942 Views)
That is what im asking.
How can i store fingerprints & search it later for recognition?
(4,940 Views)
Well...
First, you'll need to look at the fingerprint sensor's documentation.  The vendor probably provided a dll to use to communicate with the sensor.  After you've established how the fingerprints are scanned, and brought into memory, you'll have a more informed view of how to best store them.  The FBI uses wavelet compression to store images of fingerprints, your machine may just return a hash value for each fingerprint, or it may return a bitmap.  Won't know for certain until you've read the documentation.
(4,917 Views)
