Create Control - Modern vs Classic
I am using Dynamic Generation Hardware Start Trigger.vi as a template (although my question could apply to any examples vi).
My question is aesthetic in nature.
* The Controls have a white background with black text.
* When I perform "Create Control" on the terminal using the example provided by LV, it does create a white bg w/ blk text.  Great!
* When I try to create my own program and perform "Create Control" on same VI, I get control with BROWN bg w/ blk text (probably Classic group)
So the question is how do I change my setup to access my desired set of Controls/Indicators/etc from the correct group Modern/Classic/etc?
Thanks.
(3,659 Views)
Hi Bret12,
I presume that you want to have either modern or silver controls or indicators as your default control or indicator? Perhaps this link may be of your assistance: http://digital.ni.com/public.nsf/allkb/9B3AF1A89123340A86257A09004C9DBF
Open your LabVIEW >> Tools >> Options >> Front Panel  >> Change your default control to be classic, modern or silver.
Hope that helps
Warmest regards,
Lennard.C
Learning new things everyday...
(3,642 Views)
