Create Control From Reference
Using the type parameter of the Terminal is the best way to get the type of a control. If you try to do something like "get the value of the control and then ask for the type of that", you run into problems with LV classes and refnum types where the type of the value might be a child class of the type of the control.
(6,303 Views)
Accepted by topic author AristosQueue (NI)
This question is answered.
(6,302 Views)
Where do you get the two enum constants? If I right click on style to create a constant it gives me an integer and not an enum.
LabVIEW 2012
(6,287 Views)
Using the Create from Reference method seems easier:
___________________
Try to take over the world!
(6,262 Views)
What version of LV are you using? At some point, this turned from an integer to an enum.  I don't know what version, and since I wrote that code snippet using my dev build, it may be a version that hasn't released yet.
(6,229 Views)
I am using 2010 SP1
LabVIEW 2012
(6,223 Views)
