Create CIN with LabVIEW example
i would like to make a vi with a CIN and I'm training with LabVIEW examples. For create the LSB file I use LabWindows/CVI and the process is describe in the cvilvsb.h file. After the creation of LSB file, I load the source code but I have always the first error : "The object code is not load".
Why????
View the problem
(2,893 Views)
I've got two questions for you. First, what version of CVI did you use? Second, which set of instructions did you use to create this lsb file? I know there are some out there which are incorrect.
J.R. Allen
(2,893 Views)
