Create Analog Signal Output
I want to test my VI for software analog triggering(attached) to arbitrary waveform.
So I tried that using "Create Analog Signal (in "SignalExpress")" instead of using function generator with physical channel.
But "Create Analog Signal" outputs DBL-type data and I can't connect to "DAQmx Create Channel".
How can I convert DBL data to Physical channel?
How can I output a "Create Analog Signal" output to physical channel?
Or how can I test my VI to arbitrary waveform?
Please help me. Thank you.
(3,417 Views)
This is the LabVIEW board. For SignalExpress (an application and not a programming language), you should post to the SignalExpress board.
(3,408 Views)
Dennis_Knutson さんは書きました:
In the "function" table on the block diagram of LabVIEW application, there is "SignalExpressbutton.
And I want to  test my VI for software analog triggering to arbitrary waveform using LabVIEW with or without "SignalExpress"(I don't mind).
(3,396 Views)
Your code only has DAQmx Reads. It has no arb signal or a "SignalExpress". I don't know what you mean.
(3,363 Views)
