Create 2D String array from a differen 2D string array
Pardon my inexperience with this question...I'm a bit of a newb....
I am importing a .CSV file into a 20x26 string array. Of that array, I need to make a complete duplicate of three of the columns and create a 20x3 string array to be exported to a new .CSV file. I'm having trouble figuring out how to do this. I've tried using a loop and Index Array to pull elements out of the array and then either Replace Array Subset or Insert Into Array, but I get an error saying that the array types mismatch.
(3,069 Views)
No need for a loop. You can use Array Subset to extract an entire rectangle out of the array.
If you want to learn more about LabVIEW, I suggest you try looking at some of these tutorials.
___________________
Try to take over the world!
(3,066 Views)
Slice the array columns and reassemble them into a new 2D array.
(3,062 Views)
