Creat XY graph multiscale (graph multiplot) automatically?
I can Creat XY graph multiscale (graph multiplot) automatically ?
I means to detect how many of curve we have in graph and show a multiscale Which corresponds to each curve automatically.
Message 1 of 11
(4,528 Views)
Hi Sarah,
no, you cannot create new scales at runtime.
Yes, you can show and hide pre-defined scales ate runtime using property nodes.
Create as many scales as you think you will need and show them as needed!
Message 2 of 11
(4,499 Views)
Accepted by topic author Sarah_LAB
hi sarah_lab,
to get the current number of plots, you have two options.
1. the size of your value array of the xy-graph
2. increment the xy-graph-property.ActivePlot until an error occurs
also see this snippet
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 3 of 11
(4,489 Views)
hi jwscs
Message 4 of 11
(4,456 Views)
the image i posted is a .png with extra information, called a snippet (which can be identified by the top left iconification)
you can drag+drop it onto a blockdiagram
and you also can create snippets yourself easily, just have a look at the menu "Edit"->"Create Snippet from Selection"
on the top right there is the labview version with which it was created,
if you have labview >= 2016 it should work, otherwise please state your labview version, so i could make a save for previous version.
regarding the question, wether scales can be created at runtime, gerdw posted that it is not possible.
my googlefu supports that.
regards
ps: i am a gengineered gecko-eating cat 😉
Message 5 of 11
(4,450 Views)
Thank you
That's exactly what I was looking for, but how can I link each curve with its axis?
As you notice the curves are small relative to axis.
Message 6 of 11
(4,423 Views)
Hi Sarah,
each plot has a property to assign it to a scale...
Message 7 of 11
(4,419 Views)
in my example i have one graph with 4 plot,  i can't get the property of each plot?
how can get it ?
I'm sorry I'm still a beginner in labview Smiley Sad .
thank you for your attention.
Message 8 of 11
(4,415 Views)
you are half there:
since you know which plot is which,
you use the property node of the graph,
the first property you set is "Active Plot", like you do already,
then you pull down to add another property "Plot -> Y Scale Index"
hover over the properties with CTRL+h to see what the help sais about it.
have a look generally what properties there are ..
some properties you will find almost everywhere,
the lower ones are almost always the more specific ones to the thing you have the property node from/for.
regards
Message 9 of 11
(4,410 Views)
Thank you guys, the problem is solved,
Heart Heart
Message 10 of 11
(4,387 Views)
