Crashing LabVIEW when calling SetDoubleClickTime (Windows UI API)
Hmm, I think I'm calling SetDoubleClickTime correctly through the Call Library Funciton Node.  I'm even able to update the double click time.  For some reason, though, LabVIEW crashes upon execution of the function.
I suspect that I'm not handling the returned Boolean value correctly, but I've tried returning all permutations of unsigned integer, 8 bit, 16 bit, and 32 bit.  All result in crashes.
Any ideas?
Victor
(3,357 Views)
Here is what your call should look like...
I suspect it is your calling conventions.  They should be stdcall (winapi)
(3,353 Views)
J Peters,
Thank you for your prompt reply.  You were right, I was using C calling conventions instead of the Std WinAPI conventions.
Thanks for the help!
Victor
(3,346 Views)
Hi Peters,
Can you repost the Vi saved for LV 7.1 ?
- Partha ( CLD until Oct 2027 🙂 )
(3,336 Views)
Here you go, in shiny 7.1 format.
(3,320 Views)
