Crashes when calling a Vi
Hey guys,
I am very new to LabView, be aware. I have a VI (that i did not write) that, when I initially ran it, it worked just fine. I did not change it (to my knowledge) and now it crashes every time I run it. It just asks me to send an error report to NI (which I have done). I am having a hard time figuring out the problem because of course when the program crashes, I can't see what the issue is on the block diagram.
Does anybody know what could be the problem here? I can't find anything, but I'm new enough that I could easily miss plenty. Attached is the VI
Thanks for any and all help, it is much appreciated
(2,420 Views)
If you would upload a 2011 version, I would take a look at it.
Could you describe the error at all? Is there an error # and description?
(2,400 Views)
The program is nothing special but seems to call a lot of third party (hamamatsu) video capture driver VIs. See what version of that driver is installed and if there is a new version available or if there are known problems. Make sure it is compatible with your windows and LabVIEW versions, etc.
What changed? Did you upgrade LabVIEW recently or change anything else?
(I cannot even try to run it because (A) I don't have your hardware and (B) you did not include the subVIs)
(2,381 Views)
