Crash LabVIEW in one click
The buggiest LabVIEW ever (8.6.1f1) keeps on giving:
WARNING: will crash LabVIEW and you will lose any unsaved work.
 Open the INFO CLUSTER ctl in the attached LLB (28kB).
(Yes, I know it's ugly, I'm trying to work on it)
Right-click on the table.
Watch LabVIEW die.
Arrrgh.
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
(3,727 Views)
I beg to differ, LV 8.20 was the buggiest LV ever. :smileytongue:
If you tried to use LVOOP that is.
Shane.
(3,723 Views)
It crashed on LV 8.6.0 as well.  Actually appears to be a Windows crash rather than a LV crash.
(3,676 Views)
I can open it on my Mac in LV 8.6.0.
It has some serious overlap issues in the lower right hand portion.  (And that is ignoring the common font size issues seen when changing platforms).
Is there something you know needs to be fixed so you can use it?  Perhaps I could do it for you and post the modified version here.
Lynn
(3,652 Views)
Yes, I know about the overlap stuff.
Like I said, I was working on it and re-arranging stuff on the page when I discovered the bug.
Actually, I worked around it like this:
Copied the MCListBox to a blank VI.
Created a generic property node.
Linked the property node to the MCListBox.
Set the AUTOSIZE ROW height false
Set all the row heights to 23 instead of 25.
Pasted the copy in place of the original in the control I was working on.
That's what I wanted to do via dialogs, but crashed instead.
Thanks for your offer, though.
Steve Bird
Culverson.com
LinkedIn
(3,643 Views)
Steve,
OK.  Glad you found a work around.
Lynn
(3,621 Views)
Hi Everyone,
This issue has been reported to R&D for further investigation as Corrective Actio Requeset (CAR) #179492. Thanks for the feedback!
Joshua B.
(3,543 Views)
