Couple of questions regarding displaying and saving data
Hi, thanks for the help.  You are saying remove the outer-most while loop?  If I do this it may work for this vi, however this outer loop is needed for a more complex vi which I am working on and ultimately need to implement.  I am trying to connect multiple bluetooths to a single vi, see the first attachment.  I noticed that if all three outer while loops were removed, then all three bluetooths cannot connect at the same time.  When I added while loops to all three, the three bluetooth devices connected at the same time.  So, it seems I need a work around to just removing the outer while loop, unless there is a way to connect all three devices at the same time without the outer while loops.
Also, I was having trouble using typecast when I first began LabVIEW programming.  So you are saying to implement typecast as shown in attachment 2?  I will test everything when I return to the lab.
Message 11 of 11
(310 Views)
