Counting Boolean Transition
Hi. I'm new to labview. I have managed to do a boolean transition and it works. But now I want the boolean 3 true and the false 3 to count as 1. I thought it would be easy but haven't figured a way to do it.
(1,118 Views)
Hi nasha,
Whatever you have "managed": we cannot see it!
Why don't you attach your current VI? (Suggestion: when using a recent version of LabVIEW you should use "File->Save for previous" to attach a LV2019 version of your VI.)
When you want to count boolean transitions you need to detect them:
  1. compare the current state of the boolean with its previous state
  2. use the PtByPTBooleanCrossing function, which does the very same…
(1,107 Views)
