Counter as a digital Trigger
I wrote a programm for a PCI 6289. It realises a triggered analog voltage in- and output with the internal counter. With this PCIcard I can use the trigger directly with the PFI12 pin and everything is fine.
Now, I transfered it to a PC with a PCI-MIO16E1 (6070E) card.With this card the Counter isn`t linked to PFI. My question is: What can I do to bring the card to use the counter correctly. I tried already with "connect terminals" but I`m not able to select the counter in that configuration. Has someone a good idea?
Greeting Daniela
(2,450 Views)
Hi Daniela,
I think the easiest way ist to wire it directly from counter out to one PFI, isn't it?
Furthermore you can do it this way maybe:
Internally Routing Counter Signals in LabVIEW
http://digital.ni.com/public.nsf/allkb/8A85E97855EDADC98625730C00065F58?OpenDocument
regards
Tobias
(2,426 Views)
