Counter To Array
I have a numeric control that constantly changes value.
I want to create a 1 row array of all these values.
The array should contain the last 10 changes from the input and can delete any previous values.
If for example my numeric control is a counter from 1 to 100. (1 2 3 4 5 6 ... 98 99 100)
My array should always contain the last 10 digits
Array after first 10 counts = 1 2 3 4 5 6 7 8 9 10
Arrey in the middle = 43 44 45 46 47 48 49 50 51
Array at the end = 91 92 93 94 95 96 97 98 99 100
Any ideas?
Thank you in advance.
(3,758 Views)
Hi KLI,
I would rather suggest you to store the counter values into queue and
in a separate loop, dequeue it and build into array.
Prashant
(3,756 Views)
And how should I do that specific?
I'm fearly new to Labview and most of the time I know what should happen,
I just can't implement cause i'm not familiar with the functions and how to implement them.
(3,752 Views)
Found the solution myself.
For Loop with n=the number of values in the 1D array. (10)
Use auto indexing to an Array indicator.
I just have timing difficulties now.
Is there a possibilty to only store the value into the array at the moment it changes value instead of timed by the for loop iteration?
(3,749 Views)
Yes.
(what is "constantly". How different to they need to be to be considered changed? Where is the value coming from?
That does not make a lot of sense. Can you show a picture of your code?
(3,735 Views)
