Counter Task rest using DAQmx
Hi
 I built a VI using the counter on DAQmx. I am counting pulses for given time period and then computing speed of rotation. I need to reset the counter everytime the time expires.
I tried doing this several differnt ways but to no success. This works everytime I start and stop the program. If I place this in a while loop the counter never resets.
I also tried taking the difference between the counts(current -pprevious loop value). After the counter runs for a while it starts to increment the count even when it does not see a rising edge.
any suggestions to make this work would be of great help.
thanks in advance
Prasad
(2,757 Views)
Hi Prasad,
There is another discussion forum that talks about resetting counters in DAQmx.  As for the counter incrementing without seeing rising edges: one possibility could be noise in your signal, but it is difficult to tell at this point.  I suggest checking the signal that you are counting for noise. I also recommend checking to make sure that the signal is TTL compliant.
Hal L.
(2,735 Views)
