07-19-2008 01:10 AM
07-19-2008 09:15 PM
07-19-2008 09:50 PM - edited 07-19-2008 09:53 PM
07-20-2008 11:20 AM
07-20-2008 01:25 PM
07-20-2008 01:47 PM
07-21-2008 10:30 AM
Hi all,
Thanks for your reply. The goal of this program is to generate a series of continuous sine wave to support an application in real time. All sine wave will be sitting on the same axis but no two sine waves have the same initial phase.
Say for example, the first sine wave would have zero phase offset, the second sine wave will have a phase lag of maybe 10 deg and the third will be lag by 20 deg so on and so fore.
I have not add in the sine wave function because currently I am working to generate the phase offset for the sine wave first. As part of the requirement given to me, I need to generate at least 1.4M phase offset/ samples per sec.
Initial my program was only able to generate 0.8M samples per sec, but I have since correct my program and it is able to generate 4.41M samples per sec now.
My problem is solved as for now and I thanks you guys for you help.I think you guys are awesome!!!!
As much as I would like to rate those very good reply, I am unable to do so now because I am new to LV as well as this forum and has less than 50 post under my belt.
Best Regards
Zhi Hong
07-22-2008 12:34 PM - edited 07-22-2008 12:35 PM
