You could wire the loop-counter to a variable outside the loop, so you can see the number of iterations (don't forget to add 1).
You also can use the Array Size-Function. Here you get different outputs, according to the dimensions of the array to get the size of.
Here you can see what you get if you use this function:
1D-Array: one value
2D-Array: array, item 0 = number of rows, item 1 = number of columns
3D-Array: array, item 0 = number of pages, item 1 = number of rows, item 2 = number of columns
So if (in your case) you wire a 2D-Array you can use the array-size function, select item 0 of the array you get and you get the number of rows.
You can also have a look at the attachement.
Hope it helps.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
