Count number of rising edges in 1D array
I would look at using an open loop op amp configured as a comparator with a settable trip point. Because the op amp is open loop its output will either be fully on or fully off.
By the way, how much do you know about hardware? How much are you willing to learn?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 11 of 19
(2,350 Views)
@johnsold
I noticed that your VI accepts a simulated signal. But my analog channel basically gives out a 1D array devoid of a "time" parameter. Will your solution work in the absence of that parameter?
Thanks.
Prafulla.
Message 12 of 19
(2,342 Views)
@mikeporter
I am only a couple of months old in automation/data acquisiton.
I would love to learn, but I need to finish this job within a week from now.
Prafulla.
Message 13 of 19
(2,339 Views)
I would say then that you need to find a "hardware guy" to work with.
Mike...
LabVIEW Champion
Message 14 of 19
(2,326 Views)
Click on the polymorphic selector below the read function and see if you can select 1D Waveform. This will return the timing information. Move the timing function to outside the loop. No sense doing the configuration in the loop.
Message 15 of 19
(2,320 Views)
@Dennis
I am using another row from the same signal for different measurements like pressure, flow, etc.
I mentioned it before...my DAQ doesn't support reading different channels independently, so I have to take a single read and split the N Channel waveform into individual arrays. That's what's taking away the time signal.
The rest of the code is not necessary, so I didnt include it in the picture, but there are other measurements connected to that double orange line, each one is an individual 1D array.
The reason why I put the timing VI inside the while loop is because that way the measurements are realtime, instead of being otherwise unsynchronised. I don't know if I'm right in doing this.
Message 16 of 19
(2,305 Views)
If the DAQ VIs can not be configured to return the waveform data type, you can use Build Waveform and insert the timing information as dt.
Lynn
Message 17 of 19
(2,297 Views)
Your reason for putting the timing function inside the loop is just silly. You are losing the timing information because you have selected the wrong type of read. Did you even try what I suggested? It had absolutely nothing to do with acquiring multiple channels.
Message 18 of 19
(2,292 Views)
@Dennis
Oh, sorry I misread your comment, i thought you were suggesting I take 1chan waveform.
I tried that and now it does show the thick brown DBL waveform line. It works. Thanks and apologize for the mistake..
Appreciate your help!
Message 19 of 19
(2,279 Views)
