Count Boolean True's
I'm trying to create a simple counter when a boolean value is true. If I was writing line code, I would simply say that once SAVE is TRUE, then COUNT = COUNT + 1, else, COUNT = COUNT, and then drop out of the loop.
Attached is the scrren shot of what I have. The problem is the counter keeps counting until the SAVING variable goes off. I just want it to increment by one. I've tried multiple ways of doing this, however, 2 hours later and still no avail.Capture.JPG
(9,651 Views)
I used a while loop to wait for a user response.  Otherwise, the loop is not necessary.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(9,643 Views)
This gives you the option to reset the counter on the fly and it will reset on the first call.
aputman
(9,637 Views)
Accepted by topic author Superdude_123
I hope this isn't homework.
 Capture.png EDIT: OOPS
"Should be" isn't "Is" -Jay
(9,634 Views)
LabVIEW comes with a ready-to-use PtByPt-BooleanCrossing function, which makes it easy to count (rising) edges of boolean signals...
(9,618 Views)
@GerdW wrote:
LabVIEW Full or Pro (not in Base or Home) comes with a ready-to-use PtByPt-BooleanCrossing function, which makes it easy to count (rising) edges of boolean signals...
Smiley Sad NI__PtbyPt_lvlib_Boolean_Crossing_PtByPtd3.pngNI__PtbyPt_lvlib_Boolean_Crossing_PtByPtd4.png Very Sad Implies
(9,606 Views)
