Could labview version affect the output of the call library function node?
Hi guys,
I will try to explain better my problem. I am using a driver to get the results of a potentiostat while the measurement is ongoing. The driver consist of a a call library function node to comunicate with the instrument software and get the data. The driver is working in such a way that the results are updated at every data point. The problem is that the results I get has totally nothing to see whith the ones I am expecting. When I asked them they told me that this problem was probably due to the fact that they used an old version of labview and that I should contact NI to ask them for this problem. The thing is that I have used more of their drivers and all are working perfectly so the version of labview should not be a problem right? Any idea where the problem could be?
Thank you very much
(2,948 Views)
I Rodriferfe,
The version of LabVIEW shouldnt affect the output of a .dll or what ever your calling in the node, could you ask them for the settings needed inside the call function node to ensure they are correct?
Alex
(2,904 Views)
