Could labVIEW use the C# ?
Could LabVIEW use the C# in the environment of the .NET?
(3,266 Views)
What exactly are you asking?
You may want to search the forums for .Net and C# and read posts related to that.  If any of those don't answer your questions, then please post back with a clear question that more specifically tells what you are really trying to do.
(3,261 Views)
OK!Thank you very much!I am new to Labview and I am trying to use Labview .I want to know C# could be used in labview?
(3,255 Views)
LabVIEW and C# are two very different programming languages.  You can't write C# code in your LabVIEW programs, nor can you embed a LabVIEW block diagram in your C# program.  You can use .NET assemblies within LabVIEW - for that, see the help.
(3,246 Views)
Accepted by topic author yulli
LabVIEW can call .NET assemblies. Thus, if you compile the C# code into an assembly, then you can call it using the .NET functions. There's a section in the LabVIEW Help on calling .NET assemblies, and there are shipping examples as well.
(3,245 Views)
Another approach would be to write a dll in c# then call it in labview. It may be helpful to let us know a bit more about your application so we can give more informed answers
thanks
Please remember to accept any solutions and give kudos, Thanks
LV 8.6.1, LV2010,LV2011SP1, FPGA, Win7
(3,230 Views)
