Corrupted Vi
Hello. In my VI file, all the characters CR, LF were replaced by CRLF. Is it possible to restore vi?
(3,735 Views)
Hi dobrov,
The best place to restore VIs is to get them from a SCC repository!
The next best place is a backup you have made from your code before you converted all EOL chars… 😄
3rd option: try all possible combinations of replacing all CRLF chars by either CR, LF or CRLF until your VI is readable again…
(3,718 Views)
in the file there are about 5000 such characters. 3 in a level 5000.... 4.038e+2385 combinations. I already tried 10. How to recover VI of the exe?
(3,694 Views)
Hi dobrov,
Which "exe" are you talking about?
You have the options I told above. (I can add a 4th option: recreate the VI from scratch.)
Lesson learned: use a SCC system. Or create backups of your work regularly!
(3,687 Views)
You cannot recover a VI from an executable which was built using the VI.
If the executable is debuggable, you should be able to navigate to the block diagram which will help in the fourth option GerdW gave. SCC is still the correct answer though even if it doesn't help you fix the immediate problem.
(3,673 Views)
I can usually extract intact VIs from a corrupted .llb (never pull a removable drive when a .llb is open), but I've never been able to  restore a corrupted VI.
(3,631 Views)
