Correct Shared Variable behavior
I have a program, written in version 8.5, that has a shared variable used in an number of locations to shut down the program's major loops when the test system is being "shut down". I used a SV specifically to use its error in/out to force the execution order in these various loops. In 8.5 it has worked correctly, but yesterday I was helping my customer commision a new test system, using this program, and they only have 8.6, so we decided to migrate it all to this version. While still debugging the test system hardware we got an error which caused me to attempt to terminate the program. At this point I noticed that all but one loop had terminated correctly, and when I probbed the no terminating loop I discovered that it had had a hardware error, putting an error on the loop's error cluster. This caused the boolean Shared Variable to output a F rather than the T that had been written to it when I attempted the shutdown. This wasn't the behavior I remembered in my 8.5 version, so I created a quick little test, two parallel loops, one with the boolean SV in  the write mode with a control to toggle it F/T the other loop having the SV in the read mode, with its output set to stop the loop if T. I had an error cluster shift register in the second loop, with the SV's error in/out connected to it that had a control to introduce an error in the error cluster. On the system running 8.5 writing a T to the SV stops the loop regardless of the error cluster state, but on 8.6 it does not, with the SV returning a F if there is an error present.
Has this been seen by others? Which is the correct behavior?    I ended up doing a really quick change, making a "real global" and putting it into a case statement within a VI so that I could retain the ability to have the error in/out chain. I should have used a functional global, which is my normal mode rather than a "real global" but was tired and had just had an educational discussion with my customer about SV vs Globals and for the few minutes it took was in the "global mindset".  I think it might be the first global I've used in a couple of years or more, I just was so flabbergasted about finding the apparent change in behavior.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 1 of 13
(4,691 Views)
Hi LV_Pro,
how is it described in the online help? Some functions can work with input error and other not, but til now all these differences were well described in the online help.
Mike
Message Edited by MikeS81 on 01-15-2009 05:13 PM
Message 2 of 13
(4,685 Views)
The quick glance I gave it yesterday was inconclusive, mainly dealy with the other arcania of shared variables. Did a quick search on NI site yesterday too, without any answers (it was a quick search as I was squatting on the customer's laptop as I don't have internet at their facility). What bothers me is the apparent change in behavior. If it is truely operating differently it threatens a lot of work I have done. I'm pretty sure that the behavior has been consistent from the introduction of the SV, seem to recall performing an experiment quite a while ago (8.2?) to determine the error behavio, so if it has changed, whether philosophically it is now correct, it could play havoc with a lot of code out there.  Really makes it hard to maintain code, and reinforces my caution to customer about upgrading versions unless the new version has compelling features to justify it.
Putnam
LabVIEW Champion
Message 3 of 13
(4,678 Views)
So can anyone from NI wade in here and let us know how a shared variable is suppose to act if an error is present on its input, and whether it has always acted this way or recently changed? I don't have 8.6 installed on any machine I have access to at this moment to perform the same experiment that I quickly did at my customer's site. See the attached image
Putnam
LabVIEW Champion
Message 4 of 13
(4,650 Views)
Putnam,
Ran a quick test on my pc.  LV8.2 will correctly read the SV when the error is present on input.  LV 8.6 outputs the False as you described.
Message 5 of 13
(4,640 Views)
Thanks for the test, wanted to make sure that in the rush to get out of Erie before the predicted snow storm that I had actually seen what I thought I saw. Now the question is, is the difference in behavior intentional or a bug in 8.6?
Putnam
LabVIEW Champion
Message 6 of 13
(4,632 Views)
Putnam,
It appears that NI may have modified the functionality a bit.  Help in LV 8.2 for the Shared Variable just says that it will pass an error along.  Does not specify whether or not the Shared Variable will execute properly.
The LV 8.6 Help has been edited and adds the following clarification:
"error in describes error conditions that occur before this VI or function runs. The default is no error. If an error occurred before this VI or function runs, the VI or function passes the error in value to error out. This VI or function runs normally only if no error occurred before this VI or function runs. "
Message 7 of 13
(4,619 Views)
Thanks, although the info, while confirming my fears, causes me no end of grief!!!! It is changes like this that make it VERY hard for me to maintain legacy systems. Regardless of whether philosophically it was incorrect before, changing behavior has implications that can be very major. So what do I do now, have my customer petition their NI office for version 8.5 and go throught the grief of uninstalling both LabVIEW and the various other related software and then attempt, on their own, a reinstallation so that the new machine will have a development environment that matches what we used to build the first system? Or do I eat several hours worth of redoing my stuff, to remove all shared variables, build a new installation CD and try and get it to them by the beginning of next week?  I am not a happy camper. This will impact me in so many negative ways. Not a pleasant way to enter the weekend!!!!
Message Edited by LV_Pro on 01-16-2009 06:27 PM
Message Edited by LV_Pro on 01-16-2009 06:28 PM
Putnam
LabVIEW Champion
Message 8 of 13
(4,608 Views)
I am using 8.6 and this had made me really angery.  I ended up doing the samethign as you and switched to globals.
Zi
Message 9 of 13
(4,581 Views)
IMHO if a function's behavior hasn't been specifically defined for 3 major release cycles, and it performs one way, it shouldn't be changed, regardless of some philosophical "standard". Pre-8.6 it behaved by passing the error through, but still performing its own task, output the value written to it elsewhere, so why would someone think that making this behavior change to "if an error is present output the default" would not have major implications? We don't all have the luxury of rewriting our projects from scratch. Worse yet, no where in the "release notes" , "known issues", "changes since 8.6", do I see this mentioned. I wouldn't have known about it, possibly for some time, if in debugging the test system hardware we hadn't had a hardware error (which hadn't occured in the prior three months of "ringing out" the hardware) that generated and error on the error cluster. The shared variable was in the  various loops in my program to allow them to be stopped if an error was detected, or the operator was shutting down.
I would suggest that you use some type of "functional global" also called a LabVIEW 2 style global  which uses a shift register on a while loop as the memory storage element in a while loop wired to execute only once (the stop node is wired "stop")rather than "real globals" unless you encapsulate the global in a sub-vi,. You can wire an error cluster straight through to allow the resulting vi to use the error chain for execution order control, as I had planned with the Shared Variable. You can also have a write case, read case, etc. inside the loop.  Search on the this board for "functional global" or "LabVIEW 2 style" (there were no globals back then).
 My fix at the moment is that I drove 250 miles (400 km) through a snow storm  last night, am going in this morning and scrubbing the 8.6 based machine and installing 8.5.1 to make both machines identical. I would have done this originally (and not found out about this issue) but last week I forgot to pack my 8.5 DVD's and the customer only has the 8.6 ones at this time. They will be calling the NI office that handles them for their own, I suspect.
Putnam
LabVIEW Champion
Message 10 of 13
(4,541 Views)
