Copying one array value into subsequent array values
I am making an array of objects. there will be a max of 32 objects, and each object has 6 properties. (so, a 32x6 array at most).
I want to allow the user to enter one object, and copy it's properties to the next array object, but change 1 of the 6 properties (compare to drawing a line, and only moving in the "X" direction). the other 5 properties are the same (compare to no change in Y axis), so this would save some time...
I want to use one of the properties as the 'trigger' (compare to 'drawing N points, using the properties of the first one), and test for that and "fill" the next N-1 values with the same properties. That way, I would get N identical objects, offset by a little bit each ti
me. Like drawing points of a line.
But I want to save some time by copying the repetitive data (compare to color or thickness) instead of entering it each time.
these N-1 objects would be exactly the same as the first object, but displaced slightly...
Does this make sense? If so, any ideas how to best do this?
I dont have any code to show, since I am just starting this and it is trickier than I thought using Labview...
(2,816 Views)
You can use a while loop with a shift register to pass your empty array, then, using a case structure, you can add data to your array using build array, a small example is attached, hope this gives you an idea of what i mean.
(2,816 Views)
