Copying files from a project
In LabVIEW 8, with files that I want to copy which are already in a project, what is the easiest way to duplicate these into a different directory for use in a different project so that they are no longer associated with the first project?  If I copy the files to the new directory, they are still associated.  If I copy them and rename the old directory before opening them (so LabVIEW can't find the old project), then I can open them and there is the Disconnect from Library option, which I then have to use on each one manually.  Is there an easier way?
Message 1 of 1
(2,442 Views)
