Copying data from an exe program
Hello
I have an .exe program which updates temperature data real time and performs certain calculations but which I cannot change.  I would like labview to copy this data from the running program and allow me to perform and add whatever computations I need.
There is an export command allowing me to save the data I want to a .txt file, but this is slow and repetitive.  If possible I would like labview to export the data once per min and read/perform calculations on the data.
So my question is: is there a way I can get labview to control the .exe program to output data?
thank you
(2,614 Views)
Hi "Tom",
      Assuming whoever developed your .exe did not provide any convenient hooks (like Active-X), this request sounds rather ambitious.  Smiley Very Happy It's a stretch, but one solution may be to control the .exe's GUI using mouse/keyboard events.  Would the export-steps be simple to automate?  Can you afford to spend a day or two to make something work?
      The simple VI (attached) allows you to select a menu-option from the menu of another application.  It does it by recording&playing mouse events.  You'll have to figure-out some stuff on your own (like, maybe, how to automate completion of a file-dialog?)  I wouldn't/won't be surprised if someone points the way to other LabVIEW implementations for these - or other useful windows API functions.  The subject came up recently, I decided it was worth exploring!
      This example is in 7.1
Cheers.
When they give imbeciles handicap-parking, I won't have so far to walk!
(2,598 Views)
