Copying a shortcut to built-in function to a different palette
One thing I forgot to say earlier.
The snippet will drop on to your BD but you won't be able to insert it into a wire like the primitives.
So it will give you most of what you are looking for but not a true solution.
Perhaps it will be enough for your use.
Message 11 of 13
(929 Views)
Actually, I tested it and you can insert it into a wire. So it is still the best solution!
Message 12 of 13
(922 Views)
Can't believe it! WOW.
Message 13 of 13
(915 Views)
