Copying LabVIEW interface from PC to tablet - where to start?
I am currently running a LabVIEW program through my PC (Windows 10), and would like to move it over to a tablet. The reason for this is that the program runs a device that I'd like to mobilize.
The quickest option would be to use a laptop, but I'd like to have as little as possible in terms of "floating" components. I'd rather use a tablet that I'll mount onto the device in order to control it. The question is, where do I start?
I need 3 USB ports, two for LINX connection (to arduino-based PLC's) and one for the DAQ tool.
Where do I start? What should I take into consideration, in terms of running a LabVIEW program, while looking for a compatible tablet?
Thanks for your help.
(2,543 Views)
Hi easy,
When your development computer runs Windows10, then your tablet should ran the very same Windows10 environment. (No Win on ARM, no Win10X, no other OS…)
(2,534 Views)
Thank you for your reply.
Do you have any suggestions for tablets that run Windows 10 and have at least 3 USB ports?
(2,524 Views)
Hi easy,
No, I cannot suggest any type.
But you may call your favorite computer shop…
(2,507 Views)
Something else to bear in mind is the difference in screen resolution compared to what you are used to which will more than likely require a new UI layout. Big buttons, big text etc.
I am currently developing an application to run on a Microsoft Surface tablet which I am currently very impressed with...although you don't have your three USB ports (I suspect you may struggle a bit). You can quite easily get USB hubs though.
If I use the Surface pro 7 as an example, it has a documented screen resolution of 2736x1824px.
If you run it with a display scale of 100% all of the OS icons (Windows explorer, OS dialogs etc) are ridiculously small. The default that came with my surface is a scale of 200% which is much better and gives you a usable screen resolution of 912x1368 (Possibly smaller than your current development machine.
Main navigation buttons I tend to size to a minimum of 90pixels.Less important buttons I make a little smaller.
(2,500 Views)
Thanks you for replying!
The resolution is definitely something I should take into account, I will look into what into optimizing it.
Regarding the USB hub -
If I understand correctly, the USB hub allows me to use one USB port on the tablet in order to communicate with several USB devices.
If so, wouldn't that be pose a problem for continuous data being send back and forth through the single USB port?
(2,476 Views)
