Copy to NFS
Hi
I would like to ask if there is anything to copy to a non mounted NFS drive as another User.
The Idea behind i will copy upload the files only with my LabView Programm so that other Users only can lock at them.
Is there an easy solution?
(3,453 Views)
thank you for your question. I need some more information, before I can help you.
- Which OS are you using and is it a desktop pc or a RT system? Can you specify the hardware?
- Why can't you mount the NFS?
- Do you have admin rights on the file server and the locale system?
- Which Software/Version are you using?
I'm looking forward to your answer.
Best,
Florian Fischer (also speaking German)
Florian Fischer
Trainee Applications Engineering, NI Germany
Certified LabVIEW Developer
(3,401 Views)
