Copy the content of a sheet in excel and paste it in a new sheet.
How can I copy the content of the first sheet in excel and paste it in a newly created sheet. Both sheets have specific names (not sheet1 and sheet2).
(4,066 Views)
To copy the entire contents to the new sheet:
Select the Target sheet by name using property Sheets->Item("Target")
Convert target to WorkSheet
Wire target's WorkSheet->Range("A1") to specify destination
Use Sheets->Item("Source") to select the source sheet
Convert source to WorkSheet
Wire source to property WorkSheet->UsedRange
Wire to method Range->Copy, wire target range to Desination input
Note that no Paste function is required.
Michael Munroe, CLD, CTD, MCP
Automate 1M+ VI Search, Sort and Edit operations with Property Inspector 5.1, now with a new Interactive Window Manager!
Now supports full project automation using one-click custom macros or CLI.
(4,066 Views)
You need to get the cell values for the one sheet and then write those same values to the second. You need to get a reference to a paticular sheet, and then use the cell>>range.value to get the values for the sheet. The value property can be either read or write, so you could then write the same data to a different sheet following the same methods.
(4,066 Views)
