Copy and Rename a folder
I have search through the forum. And I can't found proper solution, even this is a very simple problem.
I wanted to copy folder
D:\Projects PFA\Codes Dev\Testing\10112008\1606   to
D:\Projects PFA\Codes Dev\Testing\10112008\debug_1606
and I found the "copy" and "move" function tends to copy in this way
 D:\Projects PFA\Codes Dev\Testing\10112008\debug_1606\1606
I have attached the vi. Please help.
Message 1 of 11
(6,569 Views)
         Read the detailed help of the Copy function. It tells if only the directory is specified it copies entire contents of it but if your specifying a path which contains files also you should specify with file extension.
Message 2 of 11
(6,561 Views)
Seems copy all contents inside a folder to another folder required some steps to go through.
Message 3 of 11
(6,533 Views)
So I can conclude that to copy all contents in a folder, need to go through some extra stepss
It is not as easy as
copy c:\here\* d:\there
Message 4 of 11
(6,524 Views)
Accepted by topic author engwei
engwei wrote:
So I can conclude that to copy all contents in a folder, ....
Don't "conclude". Read the online help. 🙂
If you want to copy the entire folder, you need to make sure that the new folder name does not exist. Don't create the destination folder, but delete it if it exists (careful! I would keep the confirm dialog).
 I would also strongly recommend to use path data type across everything. You constantly go back and forth between string and paths, really complicating the code.
Here's a quick draft that seems to do what you want.
Message Edited by altenbach on 11-13-2008 10:05 PM
Message 5 of 11
(6,513 Views)
Thanks for your help. It really do because I can't find the "online help" u hv mentioned. Even though "copy and rename folder" may sound easy for the expert like you, but for the newbies like me it may not sound as easy as "copy and rename folder".
Thanks again for your time and advise.
Message 6 of 11
(6,500 Views)
Simply right-click the copy icon and select "help". See if it works for you.
You can also find the entire "LabVIEW help" online, here's for example the help for copy.
(I agree you need to read it quite carefully, especially the "details" section at the bottom).
Message 7 of 11
(6,495 Views)
I see. Thanks a lot.
Message 8 of 11
(6,485 Views)
Hi could you post the CopyAndRenameFolderMOD.vi (11 KB) in version LabView 8.0
Message 9 of 11
(6,327 Views)
Message 10 of 11
(6,324 Views)
