Coordinate Transformations
Hi
Is there any VI that implements coordinate transformations like in ROS TF?
For example I have a point A measured in the Sensor frame in cartesian coordinates and I want to convert it to cartesian coordinates measured in the the global frame.
(3,453 Views)
I did some searching and I am assuming you're referring to this?
http://www.ros.org/wiki/tf
I don't know of anything higher level than the Geometry Pallete, so I would start there and see if that fits your needs.
(3,421 Views)
