Convertir un VI en application autonome
Bonjour,
J'ai créé un VI servant à mesurer le run out, et je souhaite le convertir en application autonome.
Il y a dans le VI des fonctions pour importer directement les résultats de mesure dans un tableur Excel.
Cela marche parfaitement depuis le logiciel LabVIEW.
Quand je converti mon VI en application autonome, la mesure marche bien mais le rapport Excel  ne se créé pas (ou ne s'ouvre pas).
Le VI est en pièce jointe, si quelqu'un s'y connait en application autonome depuis LabVIEW, j'ai vraiment besoin d'aide.
(1,329 Views)
Hi Robin,
@robin.drx wrote:
Good morning,
I created a VI used to measure run out, and I want to convert it into a standalone application.
There are functions in the VI to directly import the measurement results into an Excel spreadsheet.
This works perfectly from LabVIEW software.
When I convert my VI into a standalone application, the measurement works fine but the Excel report is not created (or does not open).
The VI is attached, if anyone knows about standalone applications from LabVIEW, I really need help.
Did you include the ReportGeneration functions/library as "always included" in the BuildSpec of your executable?
(1,321 Views)
Thanks for your answer,
No I didn't, how can I do this ??
I don't find the libraries in the build specifications ...
Robin
(1,304 Views)
Accepted by topic author robin.drx
Hi Robin,
You could find the libraries in the project dependencies…
(1,295 Views)
It worked, thank you so much !
Have a great day.
Robin
(1,239 Views)
